#159785 - 07/05/2003 13:20 mass sync from HD -> Empeg ??
cblake2
Okay I copied all the music off my player before I upgraded. What would be the best way to sync it back over to the empeg? I know that if you do really large xfers emplode hangs once in awhile.
TIA!
#159786 - 07/05/2003 13:22 Re: mass sync from HD -> Empeg ?? [Re: cblake2]
"Upgraded"? Do you mean the hard disk or the software?
Upgrading the software doesn't erase the music. If you upgrade the hard drive, the upgrade guide gives instructions on how to preserve the music.
#159787 - 07/05/2003 13:27 Re: mass sync from HD -> Empeg ?? [Re: cblake2]
In any case... There's a FAQ entry with a subject line that sounds like what you're asking here.
Also, regarding the files themselves, the ones you rescued off the player, read this.
#159788 - 07/05/2003 13:41 Re: mass sync from HD -> Empeg ?? [Re: tfabris]
cblake2
yeah I upgraded the HD and software at the same time
thanks for the links.
#159789 - 07/05/2003 13:46 Re: mass sync from HD -> Empeg ?? [Re: cblake2]
You should be able to get the music files straight off of the old hard disk just fine. Still, even now, assuming you didn't format the old drive yet. Instructions in the upgrade guide.
